Forensic Authentication of Bank Checks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This chapter describes an automated methodology for the forensic authentication of bank checks. The problem of check authentication is modeled as a two-class pattern recognition problem. Color and texture features are extracted from images of genuine and counterfeit checks. A support vector machine is utilized to determine check authenticity. Classification experiments involving a dataset of 50 bank checks yielded a detection accuracy of 99.0%. The automated methodology can be used by non-specialist personnel to detect check counterfeiting in a banking environment where large numbers of checks are handled on a daily basis.
431606_1_En_16_Chapter.pdf (703.41 Ko) Télécharger le fichier
hal-01758675 , version 1 (04-04-2018)
Paternité
Rajesh Kumar, Gaurav Gupta. Forensic Authentication of Bank Checks. 12th IFIP International Conference on Digital Forensics (DF), Jan 2016, New Delhi, India. pp.311-322, ⟨10.1007/978-3-319-46279-0_16⟩. ⟨hal-01758675⟩
82 Consultations
432 Téléchargements
