The zero relaxation limit for the Aw-Rascle-Zhang traffic flow model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Zeitschrift für Angewandte Mathematik und Physik Année : 2019
We study the behavior of the Aw-Rascle-Zhang model when the relaxation parameter converges to zero. In a Lagrangian setting, we use the Wave-Front-Tracking method with splitting technique to construct a sequence of approximate solutions. We prove that this sequence converges to a weak entropy solution of the relaxed system associated to a given initial datum with bounded variation. Besides, we also provide an estimate on the decay of positive waves. We finally prove that the solutions of the Aw-Rascle-Zhang system with relaxation converge to a weak solution of the corresponding scalar conservation law when the relaxation parameter goes to zero.
Goatin Laurent-Brouty - 2018.pdf (320.3 Ko) Télécharger le fichier
hal-01760930 , version 1 (06-04-2018)
hal-01760930 , version 2 (07-12-2018)
hal-01760930 , version 3 (11-04-2019)
  • HAL Id : hal-01760930 , version 2
Paola Goatin, Nicolas Laurent-Brouty. The zero relaxation limit for the Aw-Rascle-Zhang traffic flow model. Zeitschrift für Angewandte Mathematik und Physik, In press. ⟨hal-01760930v2⟩
455 Consultations
799 Téléchargements
