End-to-End Learning of Polygons for Remote Sensing Image Classification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
While geographic information systems typically use polygonal representations to map Earth's objects, most state-of-the-art methods produce maps by performing pixelwise classification of remote sensing images, then vectorizing the outputs. This paper studies if one can learn to directly output a vectorial semantic labeling of the image. We here cast a mapping problem as a polygon prediction task, and propose a deep learning approach which predicts vertices of the polygons outlining objects of interest. Experimental results on the Solar photovoltaic array location dataset show that the proposed network succeeds in learning to regress polygon coordinates, yielding directly vectorial map outputs.
girard.pdf (2.43 Mo) Télécharger le fichier
hal-01762446 , version 1 (10-04-2018)
  • HAL Id : hal-01762446 , version 1
Nicolas Girard, Yuliya Tarabalka. End-to-End Learning of Polygons for Remote Sensing Image Classification. IEEE International Geoscience and Remote Sensing Symposium – IGARSS 2018, Jul 2018, Valencia, Spain. ⟨hal-01762446⟩
536 Consultations
2928 Téléchargements
