HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Analyzing Clothing Layer Deformation Statistics of 3D Human Motions
Jinlong Yang 1 Jean-Sébastien Franco 1 Franck Hetroy-Wheeler 1, 2 Stefanie Wuhrer 1
1 MORPHEO - Capture and Analysis of Shapes in Motion
Inria Grenoble - Rhône-Alpes, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology, LJK - Laboratoire Jean Kuntzmann
Abstract : Recent capture technologies and methods allow not only to retrieve 3D model sequence of moving people in clothing, but also to separate and extract the underlying body geometry and motion component and separate the clothing as a geometric layer. So far this clothing layer has only been used as raw offsets for individual applications such as retargeting a different body capture sequence with the clothing layer of another sequence, with limited scope, e.g. using identical or similar motions. The structured, semantics and motion-correlated nature of the information contained in this layer has yet to be fully understood and exploited. To this purpose we propose a comprehensive analysis of the statistics of this layer with a simple two-component model, based on PCA subspace reduction of the layer information on one hand, and a generic parameter regression model using neural networks on the other hand, designed to regress from any semantic parameter whose variation is observed in a training set, to the layer parameteriza-tion space. We show that this model not only allows to reproduce previous motion retargeting works, but generalizes the data generation capabilities of the method to other semantic parameters such as clothing variation and size, or physical material parameters with synthetically generated training sequence, paving the way for many kinds of capture data-driven creation and augmentation applications.
Document type :
Conference papers
Complete list of metadata
Cited literature [40 references]  Display  Hide  Download
https://hal.inria.fr/hal-01763706
Contributor : Jinlong Yang Connect in order to contact the contributor
Submitted on : Wednesday, July 25, 2018 - 1:18:05 PM
Last modification on : Wednesday, May 4, 2022 - 10:02:02 AM
Identifiers
Citation
Jinlong Yang, Jean-Sébastien Franco, Franck Hetroy-Wheeler, Stefanie Wuhrer. Analyzing Clothing Layer Deformation Statistics of 3D Human Motions. ECCV 2018 - European Conference on Computer Vision, Sep 2018, Munich, Germany. pp.245-261, ⟨10.1007/978-3-030-01234-2_15⟩. ⟨hal-01763706v2⟩
Share
Metrics
Record views
709
Files downloads
834
