An Integrated Framework for Simulation and Analysis of Manual Assembly Process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Kyung-Hee Lee
  • Fonction : Auteur
  • PersonId : 1030730
Jong Youl Lee
  • Fonction : Auteur
  • PersonId : 1030731
Kyoung-Yun Kim
  • Fonction : Auteur
  • PersonId : 1030732
Sang-Do Noh
  • Fonction : Auteur
  • PersonId : 997831
Sung-Jun Kang
  • Fonction : Auteur
  • PersonId : 1030733
Doo-Myun Lee
  • Fonction : Auteur
  • PersonId : 1030734
This research aims to build an integrated framework to analyze the production flow efficiency (in terms of worker utilization) of the manual machine component assembly process. Problems related to spontaneous decision making among the workers in the manual assembly processes which cause inconsistency in the manufacturing speed, productivity, and quality. Often it is difficult to simulate all the possible situations to reduce such inconsistencies. This study aims to suggest an alternative way by introducing a prediction framework that is integrated with Modeling and Simulation (M&S) and a CART algorithm. M&S is used to create different scenarios out of the original layout for comparison. The CART algorithm is utilized to extract decision rules from the simulation results. These decision rules provide an understanding of patterns that affect workers’ utilization rate. The research goal is to adopt the rules on the simulation models, and to offer guidelines on improved alternatives for building simulation models of manual assembly process.
462132_1_En_15_Chapter.pdf (589.94 Ko) Télécharger le fichier
hal-01764216 , version 1 (11-04-2018)
Paternité
Kyung-Hee Lee, Jong Youl Lee, Kyoung-Yun Kim, Sang-Do Noh, Sung-Jun Kang, et al.. An Integrated Framework for Simulation and Analysis of Manual Assembly Process. 14th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2017, Seville, Spain. pp.162-173, ⟨10.1007/978-3-319-72905-3_15⟩. ⟨hal-01764216⟩
108 Consultations
223 Téléchargements
