NEXT: Generating Tailored ERP Applications from Ontological Enterprise Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Henk van Der Schuur
  • Fonction : Auteur
  • PersonId : 1030812
Erik van De Ven
  • Fonction : Auteur
  • PersonId : 1030813
Rolf De Jong
  • Fonction : Auteur
  • PersonId : 1030814
Dennis Schunselaar
  • Fonction : Auteur
  • PersonId : 1030815
Hajo A. Reijers
  • Fonction : Auteur
  • PersonId : 1030816
Michiel Overeem
  • Fonction : Auteur
  • PersonId : 1030817
Machiel De Graaf
  • Fonction : Auteur
  • PersonId : 1030818
Tailoring Enterprise Resource Planning (ERP) software to the needs of the enterprise still is a technical endeavor, often requiring the (de)activation of modules, modification of configuration files or even execution of database queries. Considering the large body of work on Enterprise Modeling and Model-Driven Software Engineering, this is remarkable: Ideally, one models one’s own enterprise and, at the press of a button, ERP software tailored to the needs of the modeled enterprise is generated. In this paper, we introduce NEXT, a novel model-driven software generation approach being developed with precisely this goal in mind. It uses the expressive power of ontological enterprise models (OEMs) to generate ERP cloud applications. An OEM only describes the real-world phenomena essential to the enterprise, using terms and customizations specific to the enterprise. We present our considerations during development of the OEM modeling language, which is designed to capture the specifics of enterprise phenomena in a way that technical details can be derived from it. We expect NEXT to drastically shorten the time-to-market of ERP software, from months–years to hours–days.
459826_1_En_19_Chapter.pdf (567.62 Ko) Télécharger le fichier
hal-01765268 , version 1 (12-04-2018)
Paternité
Henk van Der Schuur, Erik van De Ven, Rolf De Jong, Dennis Schunselaar, Hajo A. Reijers, et al.. NEXT: Generating Tailored ERP Applications from Ontological Enterprise Models. 10th IFIP Working Conference on The Practice of Enterprise Modeling (PoEM), Nov 2017, Leuven, Belgium. pp.283-298, ⟨10.1007/978-3-319-70241-4_19⟩. ⟨hal-01765268⟩
320 Consultations
118 Téléchargements
