Visual-Effect Dictionary for Converting Words into Visual Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Shogo Hirai
  • Fonction : Auteur
  • PersonId : 1031128
Kaoru Sumi
  • Fonction : Auteur
  • PersonId : 1031129
This paper describes a visual effect dictionary that can visually express images of words used as modifiers, such as adjectives, onomatopoeia by adding 3D objects with a visual effect. This visual effect dictionary links words and visual effects for the target objects. The same modifier can have different meanings depending on the target object thus, an intelligent algorithm to select the visual effects is required. This dictionary can be used as communication support for images that are difficult to express only by modifier words such as adjectives, onomatopoeia. When multiple regression analysis was conducted in the questionnaire results, it was found that there are appropriate visual effects and inadequate visual effects depending on nouns.
978-3-319-66715-7_18_Chapter.pdf (231.78 Ko) Télécharger le fichier
hal-01771236 , version 1 (19-04-2018)
Paternité
Shogo Hirai, Kaoru Sumi. Visual-Effect Dictionary for Converting Words into Visual Images. 16th International Conference on Entertainment Computing (ICEC), Sep 2017, Tsukuba City, Japan. pp.177-182, ⟨10.1007/978-3-319-66715-7_18⟩. ⟨hal-01771236⟩
54 Consultations
95 Téléchargements
