Image reconstruction through metamorphosis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
This article adapts the framework of metamorphosis to the resolution of inverse problems with shape prior. The metamorphosis frame- work allows to transform an image via a balance between geometrical deformations and changes in intensities (that can for instance correspond to the appearance of a new structure). The idea developed here is to reconstruct an image from noisy and indirect observations by registering, via metamorphosis, a template to the observed data. Unlike a registration with only geometrical changes, this framework gives good results when intensities of the template are poorly chosen. We show that this method is a well-defined regularization method (proving existence, stability and convergence) and present several numerical examples.
ReconstructionMetamorphosis.pdf (6.34 Mo) Télécharger le fichier
hal-01773633 , version 1 (23-04-2018)
hal-01773633 , version 2 (04-06-2018)
hal-01773633 , version 3 (29-11-2019)
  • HAL Id : hal-01773633 , version 2
Barbara Gris, Chong Chen, Ozan Öktem. Image reconstruction through metamorphosis. 2018. ⟨hal-01773633v2⟩
698 Consultations
259 Téléchargements
