Open Transactions on Shared Memory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Transactional memory has arisen as a good way for solving many of the issues of lock-based programming. However, most implementations admit isolated transactions only, which are not adequate when we have to coordinate communicating processes. To this end, in this paper we present OCTM, an Haskell-like language with open transactions over shared transactional memory: processes can join transactions at runtime just by accessing to shared variables. Thus a transaction can co-operate with the environment through shared variables, but if it is rolled-back, also all its effects on the environment are retracted. For proving the expressive power of OCTM we give an implementation of TCCS m , a CCS-like calculus with open transactions.
978-3-319-19282-6_14_Chapter.pdf (485.2 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01774945 , version 1 (24-04-2018)
Marino Miculan, Marco Peressotti, Andrea Toneguzzo. Open Transactions on Shared Memory. 17th International Conference on Coordination Languages and Models (COORDINATION), Jun 2015, Grenoble, France. pp.213-229, ⟨10.1007/978-3-319-19282-6_14⟩. ⟨hal-01774945⟩
86 Consultations
52 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
