Fluidify: Decentralized Overlay Deployment in a Multi-cloud World - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
As overlays get deployed in large, heterogeneous systems-of-systems with stringent performance constraints, their logical topology must exploit the locality present in the underlying physical network. In this paper, we propose a novel decentralized mechanism—Fluidify—for deploying an overlay network on top of a physical infrastructure while maximizing network locality. Fluidify uses a dual strategy that exploits both the logical links of an overlay and the physical topology of its underlying network. Simulation results show that in a network of 25,600 nodes, Fluidify is able to produce an overlay with links that are on average 94% shorter than that produced by a standard decentralized approach based on slicing, while demonstrating a sub-linear time complexity.
978-3-319-19129-4_1_Chapter.pdf (455.59 Ko) Télécharger le fichier
hal-01775032 , version 1 (24-04-2018)
Paternité
Ariyattu C. Resmi, François Taïani. Fluidify: Decentralized Overlay Deployment in a Multi-cloud World. 15th IFIP International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2015, Grenoble, France. pp.1-15, ⟨10.1007/978-3-319-19129-4_1⟩. ⟨hal-01775032⟩
523 Consultations
74 Téléchargements
