Longitudinal Analysis of the Run-up to a Decision to Break-up (Fork) in a Community - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Amirhosein “emerson” Azarbakht
  • Fonction : Auteur
  • PersonId : 1031407
Carlos Jensen
  • Fonction : Auteur
  • PersonId : 1031408
In this paper, we use a developer-oriented statistical approach to understand what causes people in complex software development networks to decide to fork (break away), and what changes a community goes through in the run-up to a decision to break-up. Developing complex software systems is complex. Software developers interact. They may have the same or different goals, communication styles, or values. Interactions can be healthy or troubled. Troubled interactions cause troubled communities, that face failure. Some of these failures manifest themselves as a community split (known as forking). These failures affects many people; developers and users. Can we save troubled projects? We statistically model the longitudinal socio-grams of software developers and present early indicators and warning signs that can be used to predict an imminent break-up decision.
432701_1_En_19_Chapter.pdf (254.39 Ko) Télécharger le fichier
hal-01776294 , version 1 (24-04-2018)
Paternité
Amirhosein “emerson” Azarbakht, Carlos Jensen. Longitudinal Analysis of the Run-up to a Decision to Break-up (Fork) in a Community. 13th IFIP International Conference on Open Source Systems (OSS), May 2017, Buenos Aires, Argentina. pp.204-217, ⟨10.1007/978-3-319-57735-7_19⟩. ⟨hal-01776294⟩
65 Consultations
40 Téléchargements
