Inverse design of a suspended Kirchhoff rod: From theory to practice - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Estimating the natural shape of a given hanging deformed rod, made of a known material, is a relevant problem in many industrial, graphic design, or even biological applications. To tackle this problem we examine the static Kirchhoff equations for thin elastic rods in the reverse direction, that is, when the shape at equilibrium is known and the natural shape is unknown. Our study is focussed on the case of an isotropic rod clamped at one end and free at the other, subjected to gravity.
Romero_esmc2018_0.pdf (1.32 Mo) Télécharger le fichier
hal-01778474 , version 1 (26-04-2018)
hal-01778474 , version 2 (23-05-2018)
hal-01778474 , version 3 (23-05-2018)
  • HAL Id : hal-01778474 , version 1
Victor Romero, Florence Bertails-Descoubes, Alexandre Derouet-Jourdan, Arnaud Lazarus. Inverse design of a suspended Kirchhoff rod: From theory to practice. ESMC10 2018 - 10th European Solid Mechanics Conference, Jul 2018, Bologne, Italy. pp.184302 - 184302. ⟨hal-01778474v1⟩
506 Consultations
260 Téléchargements
