KL-UCB-switch: optimal regret bounds for stochastic bandits from both a distribution-dependent and a distribution-free viewpoints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
KL-UCB-switch : un nouvel algorithme de bandit asymptotiquement optimal et minimax optimal
Hédi Hadiji
Pierre Ménard
  • Fonction : Auteur
  • PersonId : 1022182
Gilles Stoltz
In the context of K–armed stochastic bandits with distribution only assumed to be supported by [0, 1], we introduce a new algorithm, KL-UCB-switch, and prove that is enjoys simultaneously a distribution-free regret bound of optimal order √ KT and a distribution-dependent regret bound of optimal order as well, that is, matching the κ ln T lower bound by Lai and Robbins (1985) and Burnetas and Katehakis (1996).
KL-UCB+-Garivier-Hadiji-Menard-Stoltz.pdf (494.9 Ko) Télécharger le fichier
KL-UCB+-Garivier-Hadiji-Menard-Stoltz.aux (21.11 Ko) Télécharger le fichier
KL-UCB+-Garivier-Hadiji-Menard-Stoltz.synctex.gz (437.69 Ko) Télécharger le fichier
hal-01785705 , version 1 (04-05-2018)
hal-01785705 , version 2 (05-11-2019)
hal-01785705 , version 3 (28-06-2022)
  • HAL Id : hal-01785705 , version 1
Aurélien Garivier, Hédi Hadiji, Pierre Ménard, Gilles Stoltz. KL-UCB-switch: optimal regret bounds for stochastic bandits from both a distribution-dependent and a distribution-free viewpoints. 2018. ⟨hal-01785705v1⟩
Collections
UNIV-TLSE2 IMT
442 Consultations
717 Téléchargements
