On the Optimum Checkpointing Interval Selection for Variable Size Checkpoint Dumps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Samy Sadi
  • Fonction : Auteur
  • PersonId : 1031942
Belabbas Yagoubi
  • Fonction : Auteur
  • PersonId : 1031943
Checkpointing is a technique that is often employed for granting fault tolerance for applications executing in failure-prone environments. It consists on regularly saving the application’s state in another and fault independent storage such that if the application fails, it can be continued without necessarily restarting it. In this context, fixing the checkpointing frequency is an important topic which we address in this paper. We particularly address this issue considering hybrid fault tolerance and variable size checkpoint dumps. We then evaluate our solution and compare it with state of the art models, and show that our solution brings better results.
339159_1_En_49_Chapter.pdf (368.98 Ko) Télécharger le fichier
hal-01789964 , version 1 (11-05-2018)
Paternité
Samy Sadi, Belabbas Yagoubi. On the Optimum Checkpointing Interval Selection for Variable Size Checkpoint Dumps. 5th International Conference on Computer Science and Its Applications (CIIA), May 2015, Saida, Algeria. pp.599-610, ⟨10.1007/978-3-319-19578-0_49⟩. ⟨hal-01789964⟩
64 Consultations
145 Téléchargements
