Influence of particle size on the magnetocaloric properties of Mn1.30Fe0.65P0.5Si0.5 powders. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present the results of an experimental investigation on the magnetocaloric properties of Mn1.30Fe0.65P0.5Si0.5 powders with different average particle sizes. Specific heat capacity under magnetic field cp(H,T) and magnetic field induced isothermal entropy change Δsiso(H,T) were measured by Peltier calorimetry. Thermal hysteresis is found to decreases with the particle size, but the refrigerant performance, evaluated by using the product Δsiso ΔTad of the isothermal entropy change Δsiso and the adiabatic temperature change ΔTad , has only slight dependence on the particle size.
Fichier non déposé
hal-01790660 , version 1 (13-05-2018)
A. Bartok, Michaela Küpferling, Carmen Curcio, Vittorio Basso, Karim Zehani, et al.. Influence of particle size on the magnetocaloric properties of Mn1.30Fe0.65P0.5Si0.5 powders. . 7th International Conference on Magnetic Refrigeration at Room Temperature (Thermag VII). Turin, Italy, September 11-14, 2016., INRIM, Sep 2016, Torino, Italy. ⟨10.18462/iir.thermag.2016.0127⟩. ⟨hal-01790660⟩
112 Consultations
0 Téléchargements
