Trajectory Tracking For A Quadrotor Under Wind Perturbations: Sliding Mode Control With State-Dependent Gains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of The Franklin Institute Année : 2018
The problem of position tracking of a mini drone subject to wind perturbations is investigated. The solution is based on a detailed unmanned aerial vehicle (UAV) model, with aerodynamic coefficients and external disturbance components, which is introduced in order to better represent the impact of the wind field. Then, upper bounds of wind-induced disturbances are characterized, which allow a sliding mode control (SMC) technique to be applied with guaranteed convergence properties. The peculiarity of the considered case is that the disturbance upper bounds depend on the control amplitude itself (i.e. the system is nonlinear in control), which leads to a new procedure for the control tuning presented in the paper. The last part of the paper is dedicated to the analysis and reduction of chattering effects, as well as investigation of rotor dynamics issues. Conventional SMC with constant gains, proposed first order SMC, and proposed quasi-continuous SMC are compared. Nonlinear UAV simulator, validated through in-door experiments, is used to demonstrate the effectiveness of the proposed controls.
jour_GAB.pdf (3.97 Mo) Télécharger le fichier
hal-01798700 , version 1 (07-06-2018)
Gabriele Perozzi, Denis Efimov, Jean-Marc Biannic, Laurent Planckaert. Trajectory Tracking For A Quadrotor Under Wind Perturbations: Sliding Mode Control With State-Dependent Gains. Journal of The Franklin Institute, In press, ⟨10.1016/j.jfranklin.2018.04.042⟩. ⟨hal-01798700⟩
293 Consultations
1206 Téléchargements
