A Compact Representation for Multiple Scattering in Participating Media using Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Beibei Wang
Lu Wang
  • Fonction : Auteur
  • PersonId : 873867
Many materials, such as milk or wax, exhibit scattering effects; incoming light enters the material and is scattered inside, giving a translucent aspect. These effects are computationally intensive as they require simulating a large number of events. Full computations are expensive, even with accelerating methods such as Virtual Ray Lights. We present a method to encode multiple scattering effects using a neural network. We replace the precomputed multiple scattering table with a trained neural network, with a cost of 6490 bytes (1623 floats). At runtime, the neural network is used to generate multiple scattering. We demonstrate the effects combined with Virtual Ray Lights (VRL), but our approach can be integrated with other rendering algorithms.
nnRender_final.pdf (2.12 Mo) Télécharger le fichier
hal-01809890 , version 1 (07-06-2018)
Liangsheng Ge, Beibei Wang, Lu Wang, Nicolas Holzschuch. A Compact Representation for Multiple Scattering in Participating Media using Neural Networks. Siggraph 2018 Talks, Aug 2018, Vancouver, Canada. pp.1-2, ⟨10.1145/3214745.3214758⟩. ⟨hal-01809890⟩
1040 Consultations
377 Téléchargements
