Stabilization of walls in notched ferromagnetic nanowires - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Gilles Carbou
David Sanchez
In this paper we study a one-dimensional model of ferromagnetic nanowire presenting notches. We prove the existence of stable wall profiles even under a small applied magnetic field with the walls localized in notches. Moreover, in order to illustrate wall depinning by applied magnetic field, we prove the non-existence of stationary wall profiles in the presence of a large applied magnetic field.
Article-pincement.pdf (397.28 Ko) Télécharger le fichier
hal-01810144 , version 1 (07-06-2018)
  • HAL Id : hal-01810144 , version 1
Gilles Carbou, David Sanchez. Stabilization of walls in notched ferromagnetic nanowires. 2018. ⟨hal-01810144⟩
160 Consultations
74 Téléchargements
