Extraction of Relevant Resources and Questions from DBpedia to Automatically Generate Quizzes on Specific Domains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Educational quizzes are useful not only to evaluate or test the knowledge acquired by a learner, but also to help her/him to deepen knowledge about a specific domain or topic in an informal and entertaining way. The production of quizzes is a time-consuming task that can be automated by taking advantage of existing knowledge bases available on the Web of Linked Open Data (LOD). However, automatically extracting from the LOD a knowledge graph composed by the information of a set of resources which are relevant to a given specific domain or topic, is a crucial phase for the automatic generation of quizzes. To address this issue, we propose a heuristic that extracts from DBpedia a set of resources related to a given specific domain. Such heuristic has been implemented and used for the automatic generation of quizzes in the geography and privacy domains. We report a comparative user evaluation of it.
ITS2018-CR.pdf (156.93 Ko) Télécharger le fichier
hal-01811490 , version 1 (09-06-2018)
  • HAL Id : hal-01811490 , version 1
Oscar Rodríguez Rocha, Catherine Faron Zucker, Alain Giboin. Extraction of Relevant Resources and Questions from DBpedia to Automatically Generate Quizzes on Specific Domains. International Conference on Intelligent Tutoring Systems 2018, Jun 2018, Montreal, Canada. ⟨hal-01811490⟩
339 Consultations
341 Téléchargements
