Application of Graph Rewriting to Natural Language Processing - Archive ouverte HAL Access content directly
Books Year : 2018
Guillaume Bonfante
  • Function : Author
  • PersonId : 830993
Bruno Guillaume
Guy Perrier
  • Function : Author
  • PersonId : 8101
  • IdHAL : guy-perrier
The paradigm of Graph Rewriting is used very little in the field of Natural Language Processing. But graphs are a natural way of representing the deep syntax and the semantics of natural languages. Deep syntax is an abstraction of syntactic dependencies towards semantics in the form of graphs and there is a compact way of representing the semantics in an underspecified logical framework also with graphs. Then, Graph Rewriting reconciles efficiency with linguistic readability for producing representations at some linguistic level by transformation of a neighbor level: from raw text to surface syntax, from surface syntax to deep syntax, from deep syntax to underspecified logical semantics and conversely.
Not file
Dates and versions
hal-01814386 , version 1 (13-06-2018)
Identifiers
  • HAL Id : hal-01814386 , version 1
Cite
Guillaume Bonfante, Bruno Guillaume, Guy Perrier. Application of Graph Rewriting to Natural Language Processing. ISTE Wiley, 1, pp.272, 2018, Logic, Linguistics and Computer Science Set, Christian Rétoré, 1786300966. ⟨hal-01814386⟩
250 View
0 Download
Share
