Using constraint propagation for cooperative UAV localization from vision and ranging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This paper addresses the problem of cooperative localization in a group of unmanned aerial vehicles (UAV) in a bounded error context. The UAVs are equipped with cameras to tracks landmarks, and a communication and ranging system to cooperate with their neighbours. Measurements are represented by intervals, and constraints are expressed on the robots poses (positions and orientations). Each robot first computes a pose domain using only its sensors measurements, by using set inversion via interval analysis [1]. Then, through position boxes exchange, positions are cooperatively refined by constraint propagation in the group. Results are presented with real robot data, and show position accuracy improvement thanks to cooperation.
2018_coprod_kenmogne.pdf (2.84 Mo) Télécharger le fichier
hal-01814775 , version 1 (13-06-2018)
  • HAL Id : hal-01814775 , version 1
Ide-Flore Kenmogne, Vincent Drevelle, Eric Marchand. Using constraint propagation for cooperative UAV localization from vision and ranging. CoProd 2018 - Constraint Programming and Decision Making Workshop, Sep 2018, Tokyo, Japan. pp.1-5. ⟨hal-01814775⟩
242 Consultations
133 Téléchargements
