Tree based diagnostic procedures following a smooth test of goodness-of-fit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Metrika Année : 2016
This paper introduces a statistical procedure, to be applied after a goodness-of-fit test has rejected a null model, that provides diagnostic information to help the user decide on a better model. The procedure goes through a list of departures, each being tested by a local smooth test. The list is organized into a hierarchy by seeking answers to the questions " Where is the problem ? " and " What is the problem there ?. This hierarchy allows to focus on finer departures as the data becomes more abundant. The procedure controls the family-wise Type 1 error rate. Simulations show that the procedure can succeed in providing useful diagnostic information.
full_authors_manuscript copie.pdf (927.4 Ko) Télécharger le fichier
hal-01817094 , version 1 (21-06-2018)
Gilles R. Ducharme, Walid Al Akhras. Tree based diagnostic procedures following a smooth test of goodness-of-fit. Metrika, 2016, 79 (8), pp.971 - 989. ⟨10.1007/s00184-016-0585-9⟩. ⟨hal-01817094⟩
90 Consultations
175 Téléchargements
