Exploiting web ontologies for automated critical infrastructure data retrieval
Semantic web technologies play a significant role in many open data initiatives, including geo-mapping projects and platforms. At the same time, semantic principles are also promoted as a key enabling factor for multi-domain analyses of critical infrastructures as well as for improved emergency response. This chapter reviews the recent literature on ontology-based analysis and management of critical infrastructures, and proposes the use of ontology processing techniques to bridge the gap between infrastructure knowledge representation and available (often general-purpose) open data sources. In particular, it discusses an approach for matching a given critical infrastructure ontology to an ontology built on OpenStreetMap (OSM) tags that enables structured access to the associated geographical dataset.
Informatique [cs]
