Generating honeypot traffic for industrial control systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Defending critical infrastructure assets is an important, but extremely difficult and expensive task. Historically, decoys have been used very effectively to distract attackers and, in some cases, convince attackers to reveal their attack strategies. Several researchers have proposed the use of honeypots to protect programmable logic controllers, specifically those used in the critical infrastructure. However, most of these honeypots are static systems that wait for would-be attackers. To be effective, honeypot decoys need to be as realistic as possible. This chapter introduces a proof-of-concept honeypot network traffic generator that mimics a genuine control system in operation. Experiments conducted using a Siemens APOGEE building automation system for single and dual subnet instantiations indicate that the proposed traffic generator supports honeypot integration, traffic matching and routing in a decoy building automation network.
460140_1_En_11_Chapter.pdf (3.58 Mo) Télécharger le fichier
hal-01819143 , version 1 (20-06-2018)
Paternité
Htein Lin, Stephen Dunlap, Mason Rice, Barry Mullins. Generating honeypot traffic for industrial control systems. 11th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2017, Arlington, VA, United States. pp.193-223, ⟨10.1007/978-3-319-70395-4_11⟩. ⟨hal-01819143⟩
132 Consultations
487 Téléchargements
