Power Control in D2D Network Based on Game Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Kai Zhang
  • Fonction : Auteur
  • PersonId : 1033402
Xuan Geng
  • Fonction : Auteur
  • PersonId : 1033403
This paper considers power control problem based on Nash equilibrium (NE) to eliminate interference in multi-cell device-to-device (D2D) network. The power control problem is modeled as a non-cooperative game model, and a user residual energy factor is introduced in the formulation. Based on the proof of the existence and uniqueness of Nash equilibrium, a distributed iterative game algorithm is proposed to realize power control. Simulation results show that the proposed algorithm can converge to Nash equilibrium quickly, and obtain a better equilibrium income by adjusting the residual energy factor.
978-3-319-68121-4_11_Chapter.pdf (382.67 Ko) Télécharger le fichier
hal-01820923 , version 1 (22-06-2018)
Paternité
Kai Zhang, Xuan Geng. Power Control in D2D Network Based on Game Theory. 2nd International Conference on Intelligence Science (ICIS), Oct 2017, Shanghai, China. pp.104-112, ⟨10.1007/978-3-319-68121-4_11⟩. ⟨hal-01820923⟩
128 Consultations
80 Téléchargements
