Query Disambiguation Based on Clustering Techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Panagiota Kotoula
  • Fonction : Auteur
  • PersonId : 1033566
Christos Makris
  • Fonction : Auteur
  • PersonId : 992346
In this paper, we describe a novel framework for improving information retrieval results. At first, relevant documents are organized in clusters utilizing the containment metric along with language modeling tools. Then the final ranked list (ascending/descending order) of the documents that will be returned to the user for the specific query, is produced. To achieve that, firstly we extract the scores between the clusters and the query representations and then we combine the internal rankings of the documents inside the clusters using these scores as weighting factor. The method employed is based in the exploitation of the inter-documents similarities (lexical and/or semantics) after a sophisticated preprocessing. The experimental evaluation demonstrates that the proposed algorithm has the potential to improve the quality of the retrieved results.
468652_1_En_13_Chapter.pdf (358.57 Ko) Télécharger le fichier
hal-01821297 , version 1 (22-06-2018)
Paternité
Panagiota Kotoula, Christos Makris. Query Disambiguation Based on Clustering Techniques. 14th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), May 2018, Rhodes, Greece. pp.133-145, ⟨10.1007/978-3-319-92016-0_13⟩. ⟨hal-01821297⟩
227 Consultations
40 Téléchargements
