Totally Ordered Replication for Massive Scale Key-Value Stores
Scalability is one of the most relevant features of today’s data management systems. In order to achieve high scalability and availability, recent distributed key-value stores refrain from costly replica coordination when processing requests. However, these systems typically do not perform well under churn. In this paper, we propose DataFlagons, a large-scale key-value store that integrates epidemic dissemination with a probabilistic total order broadcast algorithm. By ensuring that all replicas process requests in the same order, DataFlagons provides probabilistic strong data consistency while achieving high scalability and robustness under churn.
