Bi-directional Recurrent End-to-End Neural Network Classifier for Spoken Arab Digit Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
—Automatic Speech Recognition can be considered as a transcription of spoken utterances into text which can be used to monitor/command a specific system. In this paper, we propose a general end-to-end approach to sequence learning that uses Long Short-Term Memory (LSTM) to deal with the non-uniform sequence length of the speech utterances. The neural architecture can recognize the Arabic spoken digit spelling of an isolated Arabic word using a classification methodology, with the aim to enable natural human-machine interaction. The proposed system consists to, first, extract the relevant features from the input speech signal using Mel Frequency Cepstral Coefficients (MFCC) and then these features are processed by a deep neural network able to deal with the non uniformity of the sequences length. A recurrent LSTM or GRU architecture is used to encode sequences of MFCC features as a fixed size vector that will feed a multilayer perceptron network to perform the classification. The whole neural network classifier is trained in an end-to-end manner. The proposed system outperforms by a large gap the previous published results on the same database.
ICNLSP2018.pdf (215.37 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01835440 , version 1 (11-07-2018)
Naima Zerari, Samir Abdelhamid, Hassen Bouzgou, Christian Raymond. Bi-directional Recurrent End-to-End Neural Network Classifier for Spoken Arab Digit Recognition. ICNSLP 2018 - 2nd International Conference on Natural Language and Speech Processing, Apr 2018, Algier, Algeria. pp.1-6, ⟨10.1109/ICNLSP.2018.8374374⟩. ⟨hal-01835440⟩
142 Consultations
755 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
