Simulating 6TiSCH Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transactions on emerging telecommunications technologies Année : 2018
6TiSCH is a working group at the IETF which is standardizing how to combine IEEE802.15.4 Time-Slotted Channel Hopping (TSCH) with IPv6. The result is a solution which offers both industrial performance and seamless integration into the Internet, and is therefore seen as a key technology for the Industrial Internet of Things. This article presents the 6TiSCH Simulator, created as part of the standardization activity, and which has been used extensively by the working group. The goal of the simulator is to benchmark 6TiSCH against realistic scenarios, something which is hard to do using formal models or real-world deployments. This article discusses the overall architecture of the simulator, details the different models it uses (i.e. energy, propagation), compares it to other simulation/emulation platforms, and presents 5 published examples of how the 6TiSCH Simulator has been used.
18_municio18simulating.pdf (2.12 Mo) Télécharger le fichier
hal-01838566 , version 1 (02-01-2019)
  • HAL Id : hal-01838566 , version 1
Municio Esteban, Daneels Glenn, Malisa Vucinic, Steven Latré, Jeroen Famaey, et al.. Simulating 6TiSCH Networks. Transactions on emerging telecommunications technologies, 2018. ⟨hal-01838566⟩
Collections
INRIA INRIA2
325 Consultations
1273 Téléchargements
