Selection bias in the reported performances of AD classification pipelines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neuroimage-Clinical Année : 2017
The last decade has seen a great proliferation of supervised learning pipelines for individual diagnosis and prognosis in Alzheimer's disease. As more pipelines are developed and evaluated in the search for greater performance, only those results that are relatively impressive will be selected for publication. We present an empirical study to evaluate the potential for optimistic bias in classification performance results as a result of this selection. This is achieved using a novel, resampling-based experiment design that effectively simulates the optimisation of pipeline specifications by individuals or collectives of researchers using cross validation with limited data. Our findings indicate that bias can plausibly account for an appreciable fraction (often greater than half) of the apparent performance improvement associated with the pipeline optimisation, particularly in small samples. We discuss the consistency of our findings with patterns observed in the literature and consider strategies for bias reduction and mitigation.
1-s2.0-S221315821630256X-main.pdf (1.59 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-01843390 , version 1 (27-07-2018)
Paternité
Alex F. Mendelson, Maria A. Zuluaga, Marco Lorenzi, Brian F. Hutton, Sébastien Ourselin. Selection bias in the reported performances of AD classification pipelines. Neuroimage-Clinical, 2017, 14, pp.400 - 416. ⟨10.1016/j.nicl.2016.12.018⟩. ⟨hal-01843390⟩
Collections
INRIA INRIA2
158 Consultations
121 Téléchargements
