Tampering detection and localization in images from social networks : A CBIR approach
Step 1 : Content-based image retrieval system • Goal : Find the best image in our database for a comparaison with the query • Method : 1. Find the 10 most similar images with a dot product using the de-scriptors explain below. Research is accelerated with a KD-Tree approach 2. Reorder these 10 candidates in order to find the best candidate. Define an homography between the image query and each candidate in order to found the best homography Descriptors used based on VGG19 [1] • Two sizes used : training images size or based on a kernelization step like [2] • Three vectors are analyzed based on the output of three layers: last convolutional layer C 5 with a output lenght of 512 and the fully-connected layers C 6 and C 7 with a output lenght of 4096 for both • A mean or max pooling have to be apply in the case of C 5 when we used the standard training images size and the three outputs in case of kernelized approach.
