Comparing Time Series Similarity Perception under Different Color Interpolations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2018
In previous work [1] we compared three time series visualization techniques (colorfields, horizon graphs, and line charts) in small multiples [2], in order to determine if the time series results returned from automatic similarity measures are perceived in a similar manner, irrespective of the visualization technique. Our results indicated that the notion of similarity is visualization dependent. In that first study, our colorfields implementation used a naive RGB color interpolation between red and blue hues. In this research report we describe a follow-up experiment, comparing this simple RGB interpolation to one that is perceptually uniform (CIE L*a*b*), in order to understand if the choice of color interpolation plays a role in the perception of similarity.
similarity-tech-report.pdf (1.12 Mo) Télécharger le fichier
hal-01844994 , version 1 (19-07-2018)
hal-01844994 , version 2 (24-07-2018)
hal-01844994 , version 3 (08-11-2019)
  • HAL Id : hal-01844994 , version 3
Anna Gogolou, Theophanis Tsandilas, Themis Palpanas, Anastasia Bezerianos. Comparing Time Series Similarity Perception under Different Color Interpolations. [Research Report] RR-9189, Inria. 2018. ⟨hal-01844994v3⟩
358 Consultations
191 Téléchargements
