Stability Analysis of Switched Systems with Time-Varying Discontinuous Delays *
A new technique is proposed for the stability analysis of nonlinear switched time-varying systems with time-varying discontinuous delays. It is based on an adaptation of Halanay's inequality to switched systems, combined with a recent trajectory based stability analysis technique. The result is applied to a family of the linear time-varying systems with time-varying delays. In particular, it is shown that this approach can be used for stabilization of LTV systems with time varying delays by a set of properly designed switched controllers.
Automatique
