Whole Number Recursion Formulae for High Order Clebsch-Gordan Coupling Coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Clebsch-Gordan (CG) coupling coefficients appear in many wave-based theories of matter and radiation. Here, novel whole number recursion for-mulae are presented for the exact calculation of arbitrarily high order CG coupling coefficients. Using an extended precision integer and rational number arithmetic library, these recursion formulae are shown to be up to four orders of magnitude faster than an exact prime factorisation approach. When coded in the C programming language using floating point " long double " or " double " precision, good numerical precision is obtained for the common case where the total magnetic quantum number, m 3 , is zero for all CG coefficients up to order J = 200, or J = 130, respectively, where the ranges of the principal quantum numbers are restricted to 0 ≤ j 1 ≤ J, 0 ≤ j 2 ≤ j 1 , and (j 1 − j 2) ≤ j 3 ≤ (j 1 + j 2). In this case, the calculation is up to four orders of magnitude faster than the exact prime number factorisation method used here. A C program that demonstrates these calculations is available for download at http://cgc.loria.fr.
cgc-28-jul-2018.pdf (234.98 Ko) Télécharger le fichier
hal-01851097 , version 1 (29-07-2018)
  • HAL Id : hal-01851097 , version 1
David Ritchie. Whole Number Recursion Formulae for High Order Clebsch-Gordan Coupling Coefficients. 2018. ⟨hal-01851097⟩
191 Consultations
744 Téléchargements
