Homogeneous Lyapunov functions: from converse design to numerical implementation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2018
The problem of the synthesis of a homogeneous Lyapunov function for an asymptotically stable homogeneous system is studied. First, for systems with nonnegative degree of homogeneity, several expressions of homogeneous Lyapunov functions are derived, which depend explicitly on the supremum or the integral (over finite or infinite intervals of time) of the system solutions. Second, a numeric procedure is proposed, which ensures the construction of a homogeneous Lyapunov function. The analytical results are illustrated by simulations.
LyapunovFun.pdf (771.99 Ko) Télécharger le fichier
hal-01851761 , version 1 (30-07-2018)
Denis Efimov, Rosane Ushirobira, Jaime A Moreno, Wilfrid Perruquetti. Homogeneous Lyapunov functions: from converse design to numerical implementation. SIAM Journal on Control and Optimization, 2018, 56 (5), pp.24. ⟨10.1137/17M113753X⟩. ⟨hal-01851761⟩
190 Consultations
418 Téléchargements
