Analysis and calibration of a linear model for structured cell populations with unidirectional motion : Application to the morphogenesis of ovarian follicles
We analyze a multi-type age dependent model for cell populations subject to unidirectional motion, in both a stochastic and deterministic framework. Cells are distributed into successive layers; they may divide and move irreversibly from one layer to the next. We adapt results on the large-time convergence of PDE systems and branching processes to our context, where the Perron-Frobenius or Krein-Rutman theorem cannot be applied. We derive explicit analytical formulas for the asymptotic cell number moments, and the stable age distribution. We illustrate these results numerically and we apply them to the study of the morphodynamics of ovarian follicles. We prove the structural parameter identifiability of our model in the case of age independent division rates. Using a set of experimental biological data, we estimate the model parameters to fit the changes in the cell numbers in each layer during the early stages of follicle development.
2017_ Yvinec_basaldev_linearmodel.pdf (2.32 Mo)
Télécharger le fichier
2017_ Yvinec_basaldev_linearmodel_suppl.pdf (668.59 Ko)
