A Domain Specific Language to Simplify the Creation of Large Scale Federated Model Sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Zachary T. Reinhart
  • Fonction : Auteur
  • PersonId : 1035191
Sunil Suram
  • Fonction : Auteur
  • PersonId : 1035192
Kenneth M. Bryden
  • Fonction : Auteur
  • PersonId : 1000416
This paper presents an attempt to address the challenge of modeling complex systems in which people, energy, and the environment meet. This challenge is met by developing a simple domain specific language for building systems models in a federated modeling environment. The language and its support infrastructure are designed for simplicity and ease of use. This language is demonstrated using a thermodynamic model of a biomass cookstove for the developing world as an example, and the use of the tools described in this paper to further extend that cookstove model into an end-to-end design tool for cookstoves and other energy systems for the developing world is discussed.
467210_1_En_35_Chapter.pdf (324.68 Ko) Télécharger le fichier
hal-01852607 , version 1 (02-08-2018)
Paternité
Zachary T. Reinhart, Sunil Suram, Kenneth M. Bryden. A Domain Specific Language to Simplify the Creation of Large Scale Federated Model Sets. 12th International Symposium on Environmental Software Systems (ISESS), May 2017, Zadar, Croatia. pp.420-432, ⟨10.1007/978-3-319-89935-0_35⟩. ⟨hal-01852607⟩
259 Consultations
80 Téléchargements
