Structuring and layering contour drawings of organic shapes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Complex vector drawings serve as convenient and expressive visual representations, but they remain difficult to edit or manipulate. For clean-line vector drawings of smooth organic shapes, we describe a method to automatically extract a layered structure for the drawn object from the current or nearby viewpoints. The layers correspond to salient regions of the drawing, which are often naturally associated to 'parts' of the underlying shape. We present a method that automatically extracts salient structure, organized as parts with relative depth orderings, from clean-line vector drawings of smooth organic shapes. Our method handles drawings that contain complex internal contours with T-junctions indicative of occlusions, as well as internal curves that may either be expressive strokes or substructures. To extract the structure, we introduce a new part-aware metric for complex 2D drawings, the radial variation metric, which is used to identify salient sub-parts. These sub-parts are then considered in a priority-ordered fashion, which enables us to identify and recursively process new shape parts while keeping track of Permission to make digital their relative depth ordering. The output is represented in terms of scalable vector graphics layers, thereby enabling meaningful editing and manipulation. We evaluate the method on multiple input drawings and show that the structure we compute is convenient for subsequent posing and animation from nearby viewpoints.
structuring-layering-contour-final.pdf (1.39 Mo) Télécharger le fichier
hal-01853410 , version 1 (03-08-2018)
Even Entem, Amal Dev Parakkat, Marie-Paule Cani, Loic Barthe. Structuring and layering contour drawings of organic shapes. Expressive 2018 - Joint Symposium on Computational Aesthetics and Sketch-Based Interfaces and Modeling and Non-Photorealistic Animation and Rendering, Aug 2018, Victoria, Canada. pp.1-14, ⟨10.1145/3229147.3229155⟩. ⟨hal-01853410⟩
1050 Consultations
756 Téléchargements
