Navigation Tactile 3D Augmentée Sur Mobiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
We present a pressure-augmented tactile 3D data exploration technique specifically designed for small devices. Our work is motivated by the need to support interactive visualization beyond traditional desktop workstations, especially on small portable devices. We evaluate our approach by comparing it with traditional 3D-RST (rotation, scaling, translation) using a docking task. We show that our technique increases the precision of interaction, with only little impact on interaction speed.
NavigationTactile3DAugmentéeSurMobiles.pdf (9.64 Mo) Télécharger le fichier
hal-01854463 , version 1 (06-08-2018)
  • HAL Id : hal-01854463 , version 1
Xiyao Wang, Lonni Besançon, Mehdi Ammi, Tobias Isenberg. Navigation Tactile 3D Augmentée Sur Mobiles. Journée Visu 2018, May 2018, Palaiseau, France. ⟨hal-01854463⟩
153 Consultations
99 Téléchargements
