Liveness-Driven Random Program Generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Randomly generated programs are popular for testing compilers and program analysis tools, with hundreds of bugs in real-world C compilers found by random testing. However, existing random program generators may generate large amounts of dead code (computations whose result is never used). This leaves relatively little code to exercise a target compiler's more complex optimizations. To address this shortcoming, we introduce liveness-driven random program generation. In this approach the random program is constructed bottom-up, guided by a simultaneous structural data-flow analysis to ensure that the generator never generates dead code. The algorithm is implemented as a plugin for the Frama-C framework. We evaluate it in comparison to Csmith, the standard random C program generator. Our tool generates programs that compile to more machine code with a more complex instruction mix.
lopstr2017.pdf (290.81 Ko) Télécharger le fichier
hal-01860621 , version 1 (23-08-2018)
  • HAL Id : hal-01860621 , version 1
Gergö Barany. Liveness-Driven Random Program Generation. Logic-Based Program Synthesis and Transformation. LOPSTR 2017, Oct 2017, Namur, Belgium. ⟨hal-01860621⟩
Collections
INRIA INRIA2
209 Consultations
173 Téléchargements
