Relaxing the Identically Distributed Assumption in Gaussian Co-Clustering for High Dimensional Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
C Biernacki
  • Fonction : Auteur
P D Mcnicholas
  • Fonction : Auteur
  • PersonId : 1035912
A co-clustering model for continuous data that relaxes the identically distributed assumption within blocks of traditional co-clustering is presented. The proposed model, although allowing more flexibility, still maintains the very high degree of parsimony achieved by traditional co-clustering. A stochastic EM algorithm along with a Gibbs sampler is used for parameter estimation and an ICL criterion is used for model selection. Simulated and real datasets are used for illustration and comparison with traditional co-clustering.
PrePrint3.pdf (1.62 Mo) Télécharger le fichier
hal-01862824 , version 1 (27-08-2018)
hal-01862824 , version 2 (08-12-2019)
hal-01862824 , version 3 (30-09-2020)
hal-01862824 , version 4 (21-11-2022)
  • HAL Id : hal-01862824 , version 1
M P B Gallaugher, C Biernacki, P D Mcnicholas. Relaxing the Identically Distributed Assumption in Gaussian Co-Clustering for High Dimensional Data. 2018. ⟨hal-01862824v1⟩
105 Consultations
97 Téléchargements
