Exponential Stabilization of Nonlinear Systems by an Estimated State Feedback
In this paper we investigate the stabi-lizability problem of a class of multi-input multi-output nonlinear systems which linearization at the origin is controllable and observable. Under assumptions on the nonlinear part we prove : (a) the system is globally exponentially stabilizable (G.E.S) by means of linear feedback law. (b) the system can be G.E.S using a state estimation given by an observer.
