Identifiers for Digital Objects: the Case of Software Source Code Preservation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In the very broad scope addressed by digital preservation initiatives, a special place belongs to the scientific and technical artifacts that we need to properly archive to enable scientific reproducibility. For these artifacts we need identifiers that are not only unique and persistent, but also support integrity in an intrinsic way. They must provide strong guarantees that the object denoted by a given identifier will always be the same, without relying on third parties and external administrative processes. In this article, we report on our quest for this identifiers for digital objects (IDOs), whose properties are different from, and complementary to, those of the various digital identifiers of objects (DIOs) that are in widespread use today. We argue that both kinds of identifiers are needed and present the framework for intrinsic persistent identifiers that we have adopted in Software Heritage for preserving billions of software artifacts.
main.pdf (697.57 Ko) Télécharger le fichier
hal-01865790 , version 1 (01-09-2018)
hal-01865790 , version 2 (06-09-2018)
hal-01865790 , version 3 (10-09-2018)
hal-01865790 , version 4 (05-10-2018)
Roberto Di Cosmo, Morane Gruenpeter, Stefano Zacchiroli. Identifiers for Digital Objects: the Case of Software Source Code Preservation. iPRES 2018 - 15th International Conference on Digital Preservation, Sep 2018, Boston, United States. pp.1-9, ⟨10.17605/OSF.IO/KDE56⟩. ⟨hal-01865790v4⟩
2774 Consultations
2070 Téléchargements
