A stochastic game framework for analyzing computational investment strategies in distributed computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We study a stochastic game framework with dynamic set of players, for modeling and analyzing their computational investment strategies in distributed computing. Players obtain a certain reward for solving the problem or for providing their computational resources, while incur a certain cost based on the invested time and computational power. We first study a scenario where the reward is offered for solving the problem, such as in blockchain mining. We show that, in Markov perfect equilibrium, players with cost parameters exceeding a certain threshold, do not invest; while those with cost parameters less than this threshold, invest maximal power. Here, players need not know the system state. We then consider a scenario where the reward is offered for contributing to the computational power of a common central entity, such as in volunteer computing. Here, in Markov perfect equilibrium, only players with cost parameters in a relatively low range in a given state, invest. For the case where players are homogeneous, they invest proportionally to the `reward to cost' ratio. For both the scenarios, we study the effects of players' arrival and departure rates on their utilities using simulations and provide additional insights.
Blockchain_HAL.pdf (2.7 Mo) Télécharger le fichier
hal-01870871 , version 1 (10-09-2018)
hal-01870871 , version 2 (11-09-2018)
hal-01870871 , version 3 (18-11-2018)
hal-01870871 , version 4 (20-11-2018)
hal-01870871 , version 5 (09-12-2019)
Swapnil Dhamal, Walid Ben-Ameur, Tijani Chahed, Eitan Altman, Albert Sunny, et al.. A stochastic game framework for analyzing computational investment strategies in distributed computing. 2019. ⟨hal-01870871v5⟩
365 Consultations
594 Téléchargements
