A New Family of Pairing-Friendly elliptic curves - Archive ouverte HAL Access content directly
Conference Papers Year : 2018
(1) , (2)
1
2
There have been recent advances in solving the finite extension field discrete logarithm problem as it arises in the context of pairing-friendly elliptic curves. This has lead to the abandonment of approaches based on supersingular curves of small characteristic, and to the reconsideration of the field sizes required for implementation based on non-supersingular curves of large characteristic. This has resulted in a revision of recommendations for suitable curves, particularly at a higher level of security. Indeed for a security level of 256 bits, the BLS48 curves have been suggested, and demonstrated to be superior to other candidates. These curves have an embedding degree of 48. The well known taxonomy of Freeman, Scott and Teske only considered curves with embedding degrees up to 50. Given some uncertainty around the constants that apply to the best discrete logarithm algorithm, it would seem to be prudent to push a little beyond 50. In this note we announce the discovery of a new family of pairing friendly elliptic curves which includes a new construction for a curve with an embedding degree of 54.
18_ScottGuillevic.pdf (312.58 Ko) Télécharger le fichier
Dates and versions
hal-01875361 , version 1 (17-09-2018)
Identifiers
Cite
Michael Scott, Aurore Guillevic. A New Family of Pairing-Friendly elliptic curves. International Workshop on the Arithmetic of Finite Fields - WAIFI, Lilya Budaghyan and Tor Helleseth, Jun 2018, Bergen, Norway. pp.43-57, ⟨10.1007/978-3-030-05153-2_2⟩. ⟨hal-01875361⟩
156 View
243 Download
Share
