Multidimensional analytic signal with application on graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this work we provide an extension to analytic signal method for multidimensional signals. First, expressions for separate phase-shifted components are given. Second, we show that phase-shifted components could be obtained from hypercomplex Fourier transform in the algebra of commuta-tive hypercomplex numbers. Finally we apply multidimen-sional analytic signal method to signals defined on graphs.
ssp_analytic_signal.pdf (2.56 Mo) Télécharger le fichier
hal-01878753 , version 1 (21-09-2018)
  • HAL Id : hal-01878753 , version 1
Mikhail Tsitsvero, Pierre Borgnat, Paulo Gonçalves. Multidimensional analytic signal with application on graphs. SSP 2018 - IEEE Workshop on Statistical Signal Processing, IEEE, Jun 2018, Freiburg, Germany. pp.1-5. ⟨hal-01878753⟩
102 Consultations
395 Téléchargements
