Ether and electrons in relativity theory (1900-1911) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2018
This chapter discusses the roles of ether and electrons in relativity theory. One of the most radical moves made by Albert Einstein was to dismiss the ether from electrodynamics. His fellow physicists felt challenged by Einstein's view, and they came up with a variety of responses, ranging from enthusiastic approval, to dismissive rejection. Among the naysayers were the electron theorists, who were unanimous in their affirmation of the ether, even if they agreed with other aspects of Einstein's theory of relativity. The eventual success of the latter theory (circa 1911) owed much to Hermann Minkowski's idea of four-dimensional spacetime, which was portrayed as a conceptual substitute of sorts for the ether.
2018-oup-walter.pdf (405.97 Ko) Télécharger le fichier
hal-01879022 , version 1 (21-09-2018)
  • HAL Id : hal-01879022 , version 1
Scott A. Walter. Ether and electrons in relativity theory (1900-1911). Jaume Navarro. Ether and Modernity: The Recalcitrance of an Epistemic Object in the Early Twentieth Century, Oxford University Press, 2018, 9780198797258. ⟨hal-01879022⟩
162 Consultations
789 Téléchargements
