Conference papers
A Comparative Study of Large-scale Variants of CMA-ES
Abstract : The CMA-ES is one of the most powerful stochastic numerical optimizers to address difficult black-box problems. Its intrinsic time and space complexity is quadratic-limiting its applicability with increasing problem dimensionality. To circumvent this limitation, different large-scale variants of CMA-ES with subquadratic complexity have been proposed over the past ten years. To-date however, these variants have been tested and compared only in rather restrictive settings, due to the lack of a comprehensive large-scale testbed to assess their performance. In this context, we introduce a new large-scale testbed with dimension up to 640, implemented within the COCO benchmarking platform. We use this testbed to assess the performance of several promising variants of CMA-ES and the standard limited-memory L-BFGS. In all tested dimensions, the best CMA-ES variant solves more problems than L-BFGS for larger budgets while L-BFGS outperforms the best CMA-ES variant for smaller budgets. However, over all functions, the cumulative runtime distributions between L-BFGS and the best CMA-ES variants are close (less than a factor of 4 in high dimension). Our results illustrate different scaling behaviors of the methods, expose a few defects of the algorithms and reveal that for dimension larger than 80, LM-CMA solves more problems than VkD-CMA while in the cumulative runtime distribution over all functions the VkD-CMA dominates or shows almost equal success rate with LM-CMA for budgets up to 10 4 times dimension and for all budgets up to dimension 80.
Complete list of metadatas
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-01881454
Contributor : Konstantinos Varelas <>
Submitted on : Tuesday, June 9, 2020 - 2:52:09 PM
Last modification on : Tuesday, February 9, 2021 - 11:38:02 AM
File
Second_version.pdf
Identifiers
Citation
Konstantinos Varelas, Anne Auger, Dimo Brockhoff, Nikolaus Hansen, Ouassim Elhara, et al.. A Comparative Study of Large-scale Variants of CMA-ES. PPSN XV 2018 - 15th International Conference on Parallel Problem Solving from Nature, Sep 2018, Coimbra, Portugal. pp.3-15, ⟨10.1007/978-3-319-99253-2_1⟩. ⟨hal-01881454v2⟩
Share
Metrics
Record views
148
Files downloads
626
