Static interpretation of higher-order modules in Futhark: functional GPU programming in the large - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the ACM on Programming Languages Année : 2018
We present a higher-order module system for the purely functional data-parallel array language Futhark. The module language has the property that it is completely eliminated at compile time, yet it serves as a powerful tool for organizing libraries and complete programs. The presentation includes a static and a dynamic semantics for the language in terms of, respectively, a static type system and a provably terminating elaboration of terms into terms of an underlying target language. The development is formalised in Coq using a novel encoding of semantic objects based on products, sets, and finite maps. The module language features a unified treatment of module type abstraction and core language polymorphism and is rich enough for expressing practical forms of module composition.
ICFP18-modules.pdf (693.23 Ko) Télécharger le fichier
hal-01883524 , version 1 (02-10-2018)
Martin Elsman, Troels Henriksen, Danil Annenkov, Cosmin Oancea. Static interpretation of higher-order modules in Futhark: functional GPU programming in the large. Proceedings of the ACM on Programming Languages, 2018, 2 (ICFP), pp.97:1--97:30. ⟨10.1145/3236792⟩. ⟨hal-01883524⟩
130 Consultations
202 Téléchargements
