Blockchain-based Identity Management and Data Usage Control (Extended Abstract) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2018
The General Data Protection Regulation (GDPR) [1], which will be enforceable from May 2018, introduces significant changes on the obligations of data controllers and processors in the context of the data protection legistlation of the European Union (EU). These obligations are defined by a single set of rules that should be adopted by all EU Member States including, among others, the need for explicit consent with the possibility of withdrawal and the right to erasure. The GDPR applies to data controllers (organizations) that access data of a data subject (persons) and data processors (organizations) that process data on behalf of the controller.
468319_1_En_15_Chapter.pdf (547.78 Ko) Télécharger le fichier
hal-01883615 , version 1 (28-09-2018)
Paternité
Ricardo Neisse, Gary Steri, Igor Nai Fovino. Blockchain-based Identity Management and Data Usage Control (Extended Abstract). Marit Hansen; Eleni Kosta; Igor Nai-Fovino; Simone Fischer-Hübner. Privacy and Identity Management. The Smart Revolution : 12th IFIP WG 9.2, 9.5, 9.6/11.7, 11.6/SIG 9.2.2 International Summer School, Ispra, Italy, September 4-8, 2017, Revised Selected Papers, AICT-526, Springer International Publishing, pp.237-239, 2018, IFIP Advances in Information and Communication Technology, 978-3-319-92924-8. ⟨10.1007/978-3-319-92925-5_15⟩. ⟨hal-01883615⟩
95 Consultations
82 Téléchargements
